08-28-2013 08:20 AM
Any ideas on what to do?Clarification:
12-03-2013 08:49 PM
I've uninstall the Intel® Rapid Storage Technology as suggested and restart works now!..
12-04-2013 02:09 AM
Please fix this intel, it's very annoying to have this bug.
Also the performance of this SSD is extremely poor.
12-04-2013 03:44 AM
Same Problem with HP ProBook 470 G1 Notebook (E9Y75EA# ABD).
and Intel SSDSC2BW240A401 240GB
Description:
- Cold boot, everything is fine
- Warm boot, as in reboot from windows, leads to no boot device found
Update of latest Intel RST did not help, uninstalling the complete RST neither. Legacy mode is enabled in UEFI.
Latest Driver/BIOS installed (through HP Support Manager)
12-04-2013 10:37 PM
Hello All,
Just purchased and migrated data from an Intel 520 120GB to my new Intel 530 240GB and can confirm on my HP 8570P with BIOS F.45 (latest) I am having the same restart issue. Cold boot is perfect, Restart prompts with "No Boot Device Found".
Looking forward to the firmware update soon.
@Intel, I didn't skim all 8 pages, but what parameter in the drive is causing the issue only on restart?
12-05-2013 04:10 AM
my colleague and i have the same problem with our Dell XPS 1647. we bought 2 pcs of ssd530 with 240GB 2 days ago. The BIOS unable to detect the ssd after replacing conventional HDD with the SSD.
