08-28-2013 08:20 AM
Any ideas on what to do?Clarification:
11-25-2013 11:47 AM
Are there any news about the new firmware or should I buy another SSD. I have mine for almost two months and keep looking at it
11-25-2013 12:22 PM
All,
Work on this is progressing. We anticipate having a firmware release by the end of December.
11-25-2013 03:26 PM
if you not install Intel RST driver there is no problem with the SSD
11-27-2013 12:58 AM
So in other words, we should uninstall the Intel RST driver.
BTW just want to share, when you turn off the PC and unplug all the USB devices like printer, scanner, unifying USB mouse, Display Port cable, speaker and LAN and wait for 30 mins then reconnect all the devices back and power on the PC, the Intel 530 SSD will be detected by BIOS and Windows.
If you do a restart, no problem at all, Windows will still see the SSD but if you shut down the PC for more than 5 mins. or less BIOS will not detect it again and so does Windows.
Very frustrating indeed.
Hope Intel would no disappoint us Intel Fan-boys and come up with a fix ASAP.
Tks.
11-27-2013 07:59 AM
Hi Redot,
What you describe is very different from what others on this thread are experiencing.
The reports we have are that the drive is only detected on a shutdown or full power off. The drive is NOT detected on a restart from Windows.
Am I misunderstanding the problem you are having? If the problem you are having is on a shut down or power off then please provide this information:
- Computer model and BIOS version
- SSD model and capacity
- Windows version
We may need to start a new thread.
Thanks.
