Intel 750 SSD Failure on System Resume
DF2
New Contributor II
Hi there, I recently purchased an Intel 750 SSD (2.5 inch drive, model number SSDPE2MW400G4R5) and am having some major issues with getting it to run smoothly. I originally had it as a boot drive for Windows 10 on a newly purchased Gigabyte GA-Z170X-Gaming G1 Motherboard. Everything with the installation went smoothly. The drive was connected to the motherboard via the M.2 to U.2 Add-in-Card. My experience was fine until attempting to resume from the sleep or hibernation state on my computer. Except for a few random instances, the SSD failed to resume the system from sleep and would eventually give up and restart the system altogether. Specifically, my monitors would show nothing and have no display signal, further my mouse and keyboard would quickly disconnect (after waking the computer) and stay disconnected. However, The computer fans would turn on along with all interior lights and stay running. After auto-restarting, I would then be greeted with a blue screen of death with the error message "INACCESSIBLE_BOOT_DEVICE". After the next restart (due to the BSOD), the system would then boot fine, usually taking me to the state where i had originally left the computer when it was slept. Attempting the hibernation state would cause the same error (INACCESSIBLE_BOOT_DEVICE) to appear which would then cause a restart which (after automatic windows repair at the splash screen), would load where i left off at before hibernating the computer. The ensuing hours were then dedicated to trying to find the root cause of the problem. I'll briefly summarize the actions (that I can remember) taken below:
  • Downloaded Intel SSD Toolbox and ensured all drivers were up to date.
  • Uninstalled and reinstalled intel ssd drivers along with various others such as nvidia display drivers.
  • Changed Power State options to high performance, and changed the hard drive turn off option to "never"
  • Downloaded the latest (non-beta) BIOS version for Motherboard. Specific version ID was changed from F2 to F3 (Full hardware info will be provided below)
  • Ran Windows Memory Diagnostic Test, which came back with no errors on the RAM.
  • Ran Full Diagnostic Test on SSD through Intel SSD Toolbox, which came back with no errors.
  • Re-checked for any loose connections within computer case.
  • Uninstalled various non-core programs, and closed non-critical processes before attempting to sleep. Most likely coincidental and non-repeatable, I actually did get the system to resume a few times from the sleep state doing this method. However, after restarting and closing out the same programs and processes, I could not replicate the result. A couple hours of attempts and I gave up on this path.
  • Uninstalled windows 10 altogether and reinstalled Windows 8 cleanly. The issue still persisted in the hibernation and sleep state on windows 8 as well.
At this point, I was out of ideas and decided that the best path forward was to put windows 10 on my SAMSUNG 840 EVO 500 GB to further isolate, confirm, and better diagnose the Intel 750 SSD and the drivers as the underlying issue. As a result, I disconnected all other hard drives/SSD's along with the Intel 750 SSD and installed Windows 10 on the Samsung SSD, I once again attempted the sleep and hibernation states multiple times and over several restarts after installing various programs and drivers. I did not have any issue occur once. The system resumed in roughly 7-10 seconds every time, without a problem.
I now connected all my other storage devices to my PC to once again test for problems. First of all, the Intel 750 SSD was detected and accessible under my devices and drives. I then proceeded to test the sleep state once again without issue on multiple instances. However, the total time to resume from the sleep state increased to roughly 20-30 seconds. Further, the Intel 750 SSD was now no longer detected by windows. Checking Event Viewer lists two relevant entries occurring during system resume.
  1. Error at 12:54:59 AM at Source "stornvme" (event id 11): The driver detected a controller error on \Device\RaidPort2.
  2. Warning at 12:55:04 AM at Source "disk" (event id 157): Disk 4 has been surprise removed.
At this point, I entered into Device Manager and disabled, and then re-enabled the "standard NVM Express Controller". This immediately caused windows to detect the ssd once again and fixed my issue (until the next sleep state is attempted). If anyone could provide any guidance to me on this issue it would be much appreciated. I do know that users have had similar issues with other M.2 SSD's not resuming from sleep state. One solution I've also read about is to disable link power management? However, I don't want to attempt anything else until I perhaps hear from someone with more experience on solving an issue like this. Thanks so much for reading this far, I'll provide a summary of my specs below, but please let me know anything else needed to help aid you all in solving this!
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i3/i5/i7 6xxx @ 3.50GHz 23 °C
Skylake 14nm Technology
RAM
16.0GB
Motherboard
Gigabyte Technology Co., Ltd. Z170X-GamingG1 (U3E1) 28 °C
Graphics
XB270HU (2560x1440@144Hz)
VG248 (1920x1080@144Hz)
TOSHIBA-TV (1920x1080@60Hz)
NVIDIA GeForce GTX 980 (EVGA)
ForceWare version: 353.62
SLI Enabled
Storage
223GB SanDisk SDSSDHII240G (SSD)
931GB TOSHIBA DT01ACA100 (SATA)
223GB KINGSTON SV300S37A240G (SSD)
372GB NVMe INTEL SSDPE2MW40 (Unknown)
465GB Samsung SSD 840 EVO 500GB (SSD)
Optical Drives
HL-DT-ST BDDVDRW UH12NS30
Audio
Sound Blaster ZxRi
34 REPLIES 34
jbenavides
Valued Contributor II
Hello Pc_tuner,
You already tried many troubleshooting steps, like updating BIOS and making sure the connectors are plugged correctly, among other actions.
As you mentioned, the first thing to do is to install thehttps://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-PCIe-... Intel® Solid-State Drive Data Center Family for PCIe Drivers, the latest version at this time is 1.2.0.1002. Please make sure you are using this version.
Since the Diagnostic test in the toolbox finishes with no errors, this may be due to configuration. Please consider the following:
- When booting from the Intel® SSD 750 Series, the settings required in the Motherboard vary depending on the model and vendor. Please make sure the BIOS Feature: Fast Boot is disabled, and that the OS and Boot features are set correctly. For reference, you can review the following document (this was created for motherboards with the X99 and Z97 chipsets):
http://www.intel.com/support/ssdc/hpssd/sb/CS-035481.htm Intel® High Performance Solid-State Drives — Booting an NVMe* PCI Express* Solid State Drive
- If the issue persists, try disabling Windows* Fast Startup and check if this solves the problem.
DF2
New Contributor II
Hi Jonathan, I confirmed I had the latest drivers for the intel 750 ssd via the link you provided and even uninstalled and re-installed them once again (on the intel boot drive) making sure all programs were closed during the installation. As it turns out, I forgot to install the official intel drivers for the ssd on the Samsung boot drive, however they were present on the Windows installation using the Intel SSD as the boot drive. Sorry about that, long night of troubleshooting made me forget that crucial step somehow. However, it would make no difference as this resulted in no change with the Intel SSD failing to be detected while on my current Samsung boot drive. Testing using the intel 750 SSD as the boot drive also showed no difference, with black screens eventually leading to the system restarting once more. Interestingly, the mouse and keyboard were connecting now and are lit up during the resume process but the system still does function.
I then referred to the manual that you linked me and tried to discern the general settings to use on a z170 motherboard by looking at the set up requirements for the x99 and z97 Gigabyte chipset. Through this, I changed "storage boot option control" from "legacy" to "UEFI". To be clear other relevant settings (unchanged) were:
Windows 8 features: Windows 8/10
Other PCI Device ROM priority: UEFI
Fast Boot: Disabled
CSM: Enabled
Attempting the sleep state once again yielded no change in result resulting in the SSD failing and being undetected.
I also disabled Windows Fast Startup in the power options, and then proceeded to sleep my computer. When it powered back on, the Intel SSD was still present!!! Ah Jonathan, I thought you had fixed my problem for good, but i was sadly mistaken. Attempting to navigate into the SSD gave an error message stating that the chosen file path "was not inaccessible. The request failed due to a fatal device hardware error." I then tried disabling and re-enabling the driver which then forced a reboot of the system to re-enable the driver (this had not happened before). Trying the same method once again, this time showed no ssd. I then disabled and re-enabled the driver and it showed up once more and was fully accessible. One last time, I slept the computer again (still with fast startup disabled) and this time showed the intel ssd again. However, it was once again inaccessible and required a reboot to properly re-initialize the driver.
Lastly, their were some new events of note in event Viewer (alongside previously mentioned ones in original post) with several repeating countless times in minutes. These include:
  1. Error at Source "IaNVMe" (event id 11): "The driver detected a controller error on \Device\RaidPort4."
  2. Error at Source "disk" (event id 154): "The IO operation at logical block address 0x476e0 for Disk 4 (PDO name: \Device\00000087) failed due to a hardware error." [MY NOTE: many of these errors occurred rapidly, at various block addresses]
  3. Warning at Source "Nfts" (event id 140): "The system failed to flush data to the transaction log. Corruption may occur in VolumeId: \\?\Volume{7e558c4a-ef96-4b8c-b6a4-5674c4a82e9f}, DeviceName: \Device\HarddiskVolume12. (The request failed due to a fatal device hardware error.)" [occurred numerous times]
  4. Error at "DeviceSetupManager" (event ID 131): "Metadata staging failed, result={E84DF2CA-4ACE-11E5-9BC2-806E6F6E6963} for container '0x80070490'" [occurred numerous times].
  5. Warning at "Kernel-PnP" (event id 219): "The driver \Driver\WudfRd failed to load for the device SWD\WPDBUSENUM\{4d4b97c7-4ad4-11e5-8257-806e6f6e6963}# 0000000000100000." [I believe this occurred when i tried to re-enable the driver myself and it forcing a restart to work]
How should i proceed further with this? Some bios configurations showed CSM being disabled but this was for older chipsets. Is there anyway, you could provide specific settings that you, or Intel recommends I should set with a with my specific z170 motherboard? Again, please let me know if you need further details from me! I'd like to get this sorted as soon as possible.
jbenavides
Hello pc_tuner,
Please use https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Intel® Solid-State Drive Toolbox, current version is 3.3.1, and obtain the SSD logs.
This can be retrieved by clicking the Export button in the bottom–right section of the Toolbox home window.
DF2
New Contributor II
Hello Jonathan,
I attached the logs you asked for. Let me know if anything looks out of the ordinary to you!
