04-22-2016 10:03 PM
I installed multiple DC P3700 in a server on Windows2012R2 . When I want to eject one safely , I need to detech it by operating from (eject ) task tray . But I found there are same names of P3700 .
How can I identify a slot number of P3700 from the task tray ? For example , is there any way to update the device name by using isdct in advance ?
05-12-2016 07:33 PM
>The only thing we have done is to change the labels from the OS
I am not sure if this helps because I can't understand the operation of this in detail . Would you let me know the detail how to do this ?
05-13-2016 01:39 PM
HARAKI1,
What you can try is opening "my computer" from explorer and right click the SSD so you can get the properties of the drive. Once in there, you could try to put a different name in the label under the general tab.Let us know if that works for you.
05-20-2016 09:53 AM
HARAKI1,
We would like to know if you were able to change the labels and if it worked.
We will be waiting for your response.05-21-2016 08:05 PM
Actually , it did not work . Any characters on the task tray are not changed .
05-23-2016 02:59 PM
HARAKI1,
We would like to investigate and check if there is any other way you can change this. Please allow us to research and we will get back to you.
