Drive in read-only state
Jeff_A_Intel
Intel® SSD 760p Series 2TB has put itself into a read-only state.
Took me a few days to notice, as the drive is used for high-read/low-write purposes. I was having some strange software issues, and assumed they were software bugs. While trying to figure these out I discovered I couldn't create a new directory on the drive, then realized oh, this is a hardware problem.
All data is intact, Windows 10 treats the drive like it's healthy, but no writes go through.
Drive is only a few months old. I guess if something is going to break, better that it breaks soon. ;-D
6 REPLIES 6
Diskpart immediately errors out from the Clean All command with message:
"DiskPart has encountered an error: Data error (cyclic redundancy check).
See the System Event Log for more information."
Hello Geatian.
Thank you for your reply and the information provided. You are going to receive an email shortly from our technical support department in order to further assist you. Thank you for your patience and understanding. Best regards, Josh B.Intel Customer Support.
