Data Migration Software Help
GVenn
I would like to know if I can use Data Migration Software to clone a 80GB Intel SSD to a 120GB Intel SSD
2 REPLIES 2
Jose_H_Intel1
Valued Contributor II
It should work. Please let us know if you have any other question or if by any chance you encounter any issue along the way.
More information below:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19324 Intel® Download Center
http://www.intel.com/support/ssdc/hpssd/sb/CS-034081.htm Intel® High Performance Solid-State Drives — Data Migration FAQ
http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_installation_guide_g17251.pdf http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_installation_guide_g17251.pdf
Hi Joe thanks for your reply I will now go ahead and order one.
