CPU hi load with Intel 530 SSD. Can you help me?
05-05-2014 11:44 PM
Hi, I recently change my first HDD drive with an Intel 530 SSD and after reinstall (Win 7 x64) my CPU (i7) stay overclocked all the time even when the CPU usage in task manager is under 10%. My laptop is an ACER Aspire Ethos with i7/nVidia geforce GT555m. Please help me to resolve this problem.
05-07-2014 11:57 AM
Hi CattaB, you may want to make sure everything is optimized in the System Tuner section of the https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 Intel® SSD Toolbox. You may also update to the latest https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 Intel® SSD firmware and system BIOS.
I have some questions if the above suggestions do not solve your issue:
- Can you share a screenshot showing the actual processor speed and exact model number? You may use the https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=7838 Intel® Processor Identification Utility.
- If you open Resource Monitor from the taskbar, do you see any correlation between CPU and Disk usage? Can you share some screenshots of this too?
- Does this issue happen in safe mode?
05-26-2014 11:58 PM
Hi Joe, sorry for late reply but I was out of office. I have the latest firmware on SSD and Acer notebook, everything is optimized in Intel SSD toolbox. I can not see any corelation between CPU and Disk Usage, maybe I am wrong but I want to share some sreenshots. In safe mode the cpu stay on 100% frequency, not overclocked even if the usage is about 0-5%. In normal mode the CPU stay at 2,6-2,7 Ghz.
05-30-2014 02:29 PM
I am not sure I understood this last part, what do you mean by "overclocking"? Do you mean https://www-ssl.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-tech... Intel® Turbo Boost?
Overclocking is a manual process in which the processor is set to operate at a higher clock speed than the specified by the manufacturer (Intel), this includes frequencies beyond the maximum turbo frequency.
With https://www-ssl.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-tech... Intel® Turbo Boost the processor automatically increases the clock speed up to 2.9 GHz if needed by the operating system and if other variables allow it, such as power and temperature.
If you do not see a high CPU usage in safe mode I am inclined to say this is a software issue. Do you see a particular process taking over the CPU usage in Task Manager or Resource Monitor? I could not find any in the screenshots you shared; the complete list did not fit in the window.
