10-29-2010 06:25 AM
Just put in one of these into my gigabyte P55a-UD3R and it comes up with smart command fail. Smart is disabled in bios, AHCI mode is enabled in bios, what can i do?
10-29-2010 08:33 AM
Is the issue that a SMART value is warning/critical or no SMART values can be read?
Where does it say "smart command fail"? What program are you using?
Most programs cannot read SMART data in AHCI mode. Can you read the SMART values off a HDD?
10-29-2010 08:53 AM
Use the blue SATA ports and toolbox to check SMART.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng
10-29-2010 03:54 PM
it appears when the AHCI drivers are being installed during post, when it lists my AHCI drives. I am using the intel spec USB's, don't have the gigabyte ones attached to anything
