X25-M 120 GB
Just installed the X25-M in my wife's ASUS UL10 with Win 7 64 bit. Works wonderfully!
The driver is: ICH9M-E/M SATA AHCI Controller dated 6/19/09 v 8.9.0.1023. Does this driver enable the TRIM command to work?
I know that there is a more recent driver (v 9.6.0.1014, dtd 3/23/10). Does this driver enable the TRIM command? Do I need to update?
Thanks!
1 ACCEPTED SOLUTION
mmokk
Contributor
yes, you'll need to update to at least 9.6.0.1014 for windows 7 native trim to work.
5 REPLIES 5
@duckie - Thanks!
Installed 10.1.0.1008 and works like a charm. CrystalDiskMark tests with 8.9.0.1023 (before) and 10.1.0.1008 (after) show almost identical scores so, no harm done, at least! And, now (presumably) TRIM will work.
Thanks for the help!
