Weird SSD Benchmark
02-13-2010 10:49 AM
Evertime I benchmark my intel 160gb G2 ssd drive I get a weird benchmark like this in the image. Is this normal?
02-14-2010 08:01 AM
I believe it is normal, though I haven't used HD Tach in a long time. The benchmark tool designed specfically for SSD is AS SSD: http://www.alex-is.de/PHP/fusion/downloads.php http://www.alex-is.de/PHP/fusion/downloads.php
02-14-2010 09:04 AM
02-14-2010 10:12 AM
Your 4K-64Thrd looks a bit low as does your overall score. Have you updated to latest firmware? I have an older version of AS SSD and this is one of the tests I ran (test results do vary).
The driver you are using is not the same as my driver. You need to run optimizer when not using msahci default AHCI driver. Are you running in AHCI mode?
02-14-2010 10:22 AM
I have an AMD 780g motherboard using the amd AHCI driver. It loads standard with windows 7. Also the ssd toolbox still finds my ssd drive and runs on it.
