Update from Intel's NAND Solutions Group - Firmware issue
11-16-2009 09:47 PM
• Intel has confirmed an issue with the firmware update process for 34nm (G2) Intel® X25-M SSDs (80GB and 160GB). This predominantly affected Windows* 7 (64bit) users during or immediately after the upgrade process to 02HA firmware using the firmware update tool (version 1.3). Intel plans to release a fix for this issue by the end of November 2009.
• Please see below to decide what you should do:
• If you have not upgraded to 02HA but using 02G2 or 02G9 – then use new tool when available to upgrade to new firmware to get Trim support and better sequential write performance (160GB)
• If you have successfully upgraded to 02HA - then continue using the SSD, there are no known issues.
• If you have received a SSD with 02HA pre installed – then continue using the SSD, there are no known issues.
• If you have unsuccessfully upgraded to 02HA - then contact Intel Customer Support for instructions on how to recover the SSD via secure erase or return SSD to Intel for replacement or refund.
Alan
Intel Corporation
12-01-2009 09:52 AM
You expect END-USERs running around with that sort of stuff? I think they'll do more harm than good with that
12-01-2009 12:59 PM
You're probably right on that account, I just wanted to point out that SMART-data CAN be manipulated.
11-18-2009 11:07 AM
The issue is with Windows 7 64-bit and I upgraded the firmware to 3 SSD's using Windows 7 64-bit. Now, that strikes me as quite remarkable!
11-30-2009 10:58 PM
here it came.. the end of november, the first of december..
nor Firmware, no SSD Toolbox !
HapPy ThAnKs GiVinG InTeL !
12-04-2009 03:46 PM
I just bought 2 80gb G2 drives, on the packages they have FW 02G9. Do I need to update the firmware? (if so, what is the benefit and which version do I want)
One drive will be running in a win xp 32 bit system. Can I use the old SSD Toolbox to manually TRIM/wipe it? (how often, if so)
2nd drive will be running win 7 64bit, which I guess has TRIM built in (if I'm running AHCI mode). So I don't have to do anything?
Thanks for any help.
