Update from Intel's NAND Solutions Group - Firmware issue
Alan_F_Intel
New Contributor III
New Contributor III
• Intel has confirmed an issue with the firmware update process for 34nm (G2) Intel® X25-M SSDs (80GB and 160GB). This predominantly affected Windows* 7 (64bit) users during or immediately after the upgrade process to 02HA firmware using the firmware update tool (version 1.3). Intel plans to release a fix for this issue by the end of November 2009.
• Please see below to decide what you should do:
• If you have not upgraded to 02HA but using 02G2 or 02G9 – then use new tool when available to upgrade to new firmware to get Trim support and better sequential write performance (160GB)
• If you have successfully upgraded to 02HA - then continue using the SSD, there are no known issues.
• If you have received a SSD with 02HA pre installed – then continue using the SSD, there are no known issues.
• If you have unsuccessfully upgraded to 02HA - then contact Intel Customer Support for instructions on how to recover the SSD via secure erase or return SSD to Intel for replacement or refund.
Alan
Intel Corporation
24 REPLIES 24
[Quote]
[/Quote]
Why do you specify 160GB? I've got a new (still in sealed package) 80GB. Is there an additional problem with the 80GB?
Kenneth Tan
The firmware is for 80GB and 160GB drives, but only the 160 GB drive will have better sequencial speed after the upgrade.
Because the 160 GB drive has 2 times the number of chips of the 80GB, they could increase its sequencial speed a bit in the new firmware.
afrosty, thanks for keeping us informed and providing an ETA. Very much appreciated!
afrosty, thanks for keeping us informed and providing an ETA. Very much appreciated! Just click the "Announcement" link at the top of this forum's index.<!-- [DocumentBodyEnd:cd5fa88f-c2f9-4ece-af5d-5009e9ee0fd6] --><!-- BEGIN attachments --><!-- END attachments -->
So your point exactly is ?
That I should not thank afrosty because the information is also accessible in another way and not only at the top of the thread that he created?
