Update from Intel's NAND Solutions Group - Firmware issue
Alan_F_Intel
New Contributor III
New Contributor III
• Intel has confirmed an issue with the firmware update process for 34nm (G2) Intel® X25-M SSDs (80GB and 160GB). This predominantly affected Windows* 7 (64bit) users during or immediately after the upgrade process to 02HA firmware using the firmware update tool (version 1.3). Intel plans to release a fix for this issue by the end of November 2009.
• Please see below to decide what you should do:
• If you have not upgraded to 02HA but using 02G2 or 02G9 – then use new tool when available to upgrade to new firmware to get Trim support and better sequential write performance (160GB)
• If you have successfully upgraded to 02HA - then continue using the SSD, there are no known issues.
• If you have received a SSD with 02HA pre installed – then continue using the SSD, there are no known issues.
• If you have unsuccessfully upgraded to 02HA - then contact Intel Customer Support for instructions on how to recover the SSD via secure erase or return SSD to Intel for replacement or refund.
Alan
Intel Corporation
24 REPLIES 24
I fear it is but I suggest to wait for the new version of the Tool to see if it can help in fixing your errors.
You can try one more thing, run HDDerase again and then format the drive in Windows 7.
HDDerase did not fix SMART error problem for me
AFAIK there is nothing that an end user can do to change S.M.A.R.T data.
Not quite true. There are products on the market that can manipulate just about anything on a drive, even S.M.A.R.T. data.
Check this out: http://www.deepspar.com/pdf/DeepSparPC-3000UDMABrochure8.0.pdf http://www.deepspar.com/pdf/DeepSparPC-3000UDMABrochure8.0.pdf
