09-22-2010 08:07 PM
Hi maybe someone could help me out I try running the toolbox on windows7 the drive shows up but when I try to click it it keeps refreshing and all the boxes to the left are grayed out.........any ideas.
09-22-2010 09:11 PM
r u using the latest ssd toolbox? Intel SSD? try restart your machine and make sure ssd connects properly
so far i got ssdtoolbox running ok on two windows 7 machine.
09-23-2010 03:25 AM
Yes it is V2.I believe it is connected properly sinse it has the os on it and boots up with no problem.
09-23-2010 03:07 PM
Are you running the sys in AHCI mode if not the tool box won't work right
09-25-2010 07:44 AM
If it is continually refreshing as you say, it could be a conflict with other software on your PC.
