08-21-2010 06:34 AM
Hi all SSD users
I´m running XP pro 32 on Intel X25-V with system recovery enabled and vssvc.exe running. When I start Optimizer (v1.3.0.000) I get the following message:
"The VSS (Volume Shadow Copy) service is either disabled or not functioning properly. If you run the Intel® SSD Optimizer with the VSS service disabled, previously-created restore points or other shadow copies created by the operating system or third-party applications may become corrupt. If you intentionally disabled the VSS service for performance or other reasons and wish to continue running the Intel SSD Optimizer, click Continue."
If I click continue will Optimizer work properly? Is there anyone out there running Optimizer 1.3 and having the same problem?
08-24-2010 08:27 PM
if you are using a non-English OS, check this out: http://www.intel.com/support/ssdc/hpssd/x25m/sb/CS-031622.htm
08-25-2010 09:31 AM
Thanx for your tip, but it don´t really answer my question. Will it work if I ignore the warning?
