SSD Toolbox: No Optimization due to " Volume Shadow Copy Service data"
12-27-2009 03:46 PM
Hi all and support!
In an other thread some users had problems running the new optimizer in the SSD Toolbox 1.2.
Me too - 😉
Running XP pro 32 bit with system recovery disabled (via ssd tweaker util) and volume shadow copy service (vssvc.exe) manually disabled.
There are no system recovery points stored. Additionally I stopped all services that are bound to the backup software Acronis True Image Home
that I have installed. Even when starting XP in secured mode (German: Abgesicherter Modus via F8 at start time) the optimizer didn't start.
Version 1.1 worked so far I could see - I didn't check the variation of access times.
Any hint or clue?
Thomas
SSD X-25M 160GB Gen2 (FW 02HD), Notebook Samsung Aura Danica, XP Home SP3 32-bit, SSD Toolbox 1.2.0
12-30-2009 01:07 PM
Only one Win XP partition (full size, NTFS) and w/o any hidden (service) partitions.
IMO this is Toolbox 1.2.0 bug. When I stopped the Volume Shadow Copy service and start Toolbox Optimizing then Toolbox started the Volume Shadow Copy service and show error (but show error too when VSC service is definitely turned off).
12-30-2009 01:49 PM
Don't know if this helps, but you can try to delete volume shadow copy files:
(Note: be careful with what you select to delete)
12-30-2009 02:15 PM
I'm experiencing this problem too.
XP Pro 32 bits.
SSD X-25M 80GB G2 FW 02HD (One partition full capacity)
SSD Toolbox 1.2.0
I hope next Toolbox version will solve this issue.
12-31-2009 04:49 AM
I have the same problem:
XP Pro 32 bits.
SSD Toolbox 1.2.0
Please Intel work on a fix!
01-05-2010 07:32 AM
I have the same problem on Windows XP Pro.
The command "vssadmin list shadows" does not find any Volume Shadow Copy Data.
