SSD Performance problem on H67
03-31-2011 02:48 PM
I recently built a Demonstration PC to show my customers the speed of the latest Intel Sandy Bridge CPU, Windows 7 and SSD's.
The specs are:
Gigabyte H67MA-D2H Intel Core i5 23002x2GB Kingston DDR3-1333MHZ OCZ 60G Vertex II E Series SSD Microsoft Windows 7 Home Premium 64No dedicated graphics card.
I noticed the SSD was not performing like it should (below) and could not work out why.
I opened a thread over on the OCZ forum but as SB is new they could not work it out iether.
So I set about working it out for myself and found the problem. I'm hoping Intel provide a solution.
I found the same problem on a new PC I built over the weekend using the new B3 mobo with the fixed chipset so that is not the problem.
Fault Finding Log:
Loaded optimized bios defaultschanged bios to AHCIInstalled Win 7 HP x64 SP1 to 1TB WD Black WD1002FAEX on SATA III Deleting all partitions first.Installed Lan DriverTurned off UACSecure erased SSD with OCZ toolbox v2.33initialised, partitioned and quick formatted SSDRan ATTO v2.46As you can see the performance is back so it isn't a hardware problem or a Windows problem or an SP1 problem!
Installed latest Intel INF 9.2.0.1025
No great change.
Installed Latest Intel HD Family GFX driver 15.21.12.64.2321
Bingo!!! That certainly looks like the problem. Who would have guessed a graphics driver could do that!
Has anyone else seen performance problems with SSD's on the H67 chipset?
Any ideas on how to fix this problem?
05-09-2011 11:22 AM
im still having slow writes with graphics driver 2361
07-11-2011 09:53 AM
finally figured out the slow writes with gigabyte h67 and ocz agility 2 60gb it all has to do with the 100gb windows 7 system partition install windows without and write speeds are back from the 215's to the 260's. now i can sleep at nite!
07-18-2011 08:53 AM
ok i was wrong on the previous post but this is the real solution for any one interested go into the bios and disable c3/c6 state but it also disables turbo boost and you will never have slow write speeds again guaranteed!
