SSD firmware update fail
03-12-2011 12:13 PM
I dont have a second pc to do the firmware update for my SSD.
I tryed multisetting
-AHCI-Legacy : On scanning SSD it stuck there for eternity
-AHCI-Native : It pass the scanning but when it start the firmware update it fail saying:
--Check if no password on SSD: indeed, no pwd
--Check to enable SMART: yes
--Look under go/support.. which I did and I didnt find any usefull help for my situation.
So I update bios, same result for the update...
Any idee what could cause the scanning to freeze? on AHCI legacy mode ?
My Laptop: Alienware M17x version1
Best regard,
03-14-2011 08:09 PM
What SATA controller/chipset is being utilized? Also, which drive are you attempting to update?
03-15-2011 07:39 PM
Trying to upgrade the firmware: v1.7 for the Intel® X25-M ( 80gb )
Chipset nvidia nforce 730i
bios version 5
03-16-2011 05:20 AM
I am having the same issue with my 160gb x25m
