β12-14-2009 09:57 AM
Hello at all,
as you can see at the thread title, i have a problem with the sequential read speed.
My system is a Dell Vostro 1700 with 2 SATA drives.
One of them i have changed to the X25-M... The other is a normal drive.Crystal Disk Info tells me, that the drive is running on SATA-300.
System is Windows 7 64 bit.
The System is fast in relation to the ordinary drive
Boot time about 23 sek.Shutdown time about 13 sek.The starting time of all programmes is very fast too.Click and running...But i think there should be more read speed than only 138 mb...
Write speed is ok. About 75 to 78 Mb/s.What can i do to improve the speed?
Where should i search for the problem?I hope my english is good enough that you understand what i mean.
Greetings from germany
Brain11β12-14-2009 05:31 PM
OK...
My Dell has a Feature called Flash Cache Module wich i can enable oder disable in the bios
I have done some benchmarks with different configurations
SATA with Flash Modul---------------------------------------------------------------CrystalDiskMark 3.0 x64 Beta2 (C) 2007-2009 hiyohiyo Crystal Dew World : http://crystalmark.info/ http://crystalmark.info/---------------------------------------------------------------Sequential Read : 137.862 MB/s
Sequential Write : 78.328 MB/s Random Read 512KB : 127.132 MB/s Random Write 512KB : 62.056 MB/s Random Read 4KB (QD=1) : 16.006 MB/s [ 3907.6 IOPS] Random Write 4KB (QD=1) : 21.102 MB/s [ 5151.9 IOPS] Random Read 4KB (QD=32) : 99.109 MB/s [ 24196.5 IOPS] Random Write 4KB (QD=32) : 44.709 MB/s [ 10915.4 IOPS]Test : 500 MB [C: Used 48.9% (36.4/74.4 GB)]
Date : 2009/12/10 15:28:41 OS : Windows 7 [6.1 Build 7600] (x64)SATA without Flash Modul---------------------------------------------------------------CrystalDiskMark 3.0 x64 Beta2 (C) 2007-2009 hiyohiyo Crystal Dew World : http://crystalmark.info/ http://crystalmark.info/---------------------------------------------------------------Sequential Read : 138.847 MB/s
Sequential Write : 81.792 MB/s Random Read 512KB : 127.047 MB/s Random Write 512KB : 71.190 MB/s Random Read 4KB (QD=1) : 16.419 MB/s [ 4008.6 IOPS] Random Write 4KB (QD=1) : 28.361 MB/s [ 6924.1 IOPS] Random Read 4KB (QD=32) : 99.634 MB/s [ 24324.8 IOPS] Random Write 4KB (QD=32) : 67.155 MB/s [ 16395.2 IOPS]Test : 500 MB [C: Used 50.4% (37.5/74.4 GB)]
Date : 2009/12/15 0:55:38 OS : Windows 7 [6.1 Build 7600] (x64)ATA without Flash Modul
---------------------------------------------------------------CrystalDiskMark 3.0 x64 Beta2 (C) 2007-2009 hiyohiyo Crystal Dew World : http://crystalmark.info/ http://crystalmark.info/---------------------------------------------------------------Sequential Read : 228.947 MB/s
Sequential Write : 84.494 MB/s Random Read 512KB : 159.216 MB/s Random Write 512KB : 74.257 MB/s Random Read 4KB (QD=1) : 16.879 MB/s [ 4121.0 IOPS] Random Write 4KB (QD=1) : 35.263 MB/s [ 8609.0 IOPS] Random Read 4KB (QD=32) : 19.982 MB/s [ 4878.5 IOPS] Random Write 4KB (QD=32) : 51.320 MB/s [ 12529.3 IOPS]Test : 500 MB [C: Used 50.4% (37.5/74.4 GB)]
Date : 2009/12/15 0:44:30 OS : Windows 7 [6.1 Build 7600] (x64)it seems to be impossible to get the speed off the different modes combined into one...the fastest mode at usual use at work seems to be SATA without Flash Modul
β12-16-2009 05:09 PM
Do you have TRIM firmware installed, BIOS set to AHCI?
β12-17-2009 05:26 AM
yes, i have installed the actual firmware and ahci is enabled. I have tested all modes and all combinations of modes, as you can see my crystal test results
β12-17-2009 10:53 AM
The sequential read speed should be at least 250, I haven't checked your other scores. Can you post a picture of the results from Crystal Disk Mark?
