Scheduled Optimization on Heavily Used Data Drive
05-02-2011 02:42 PM
We're testing an x-25v 40gb on a data ingester running xp-pro receiving a feed at around 10Mbps. Total drive use is consistent at around 10GB with thousands of small files updating every hour. So far the drive has performed much better than the striped raids we've been using. I've only optimized the drive twice in a week & it's still doing a better job on scheduled output. I would really like to schedule the optimization to run once every few days, but I don't want to shutdown the service & interrupt the feed. I've seen the warning that only 1GB will be available for use during optimization, & I don't believe the system would exceed that in the brief period required for optimization (though the service was shutdown while optimizing).
Would this be worth trying on a non-os drive? What are the potential hazards?
Also, how urgent should our move to the 320 series be? We recieved 3 last Friday after noting the performance on this test unit and contending with speed/fragmentation issues on other ingesters running striped raid. I'm thinking perhaps we should swap out the value series on the test box prior to putting it into production.
05-04-2011 12:52 AM
The "Intel SSD Toolbox.exe" is a GUI-only binary from what I can tell; no argv parsing exists in it. There's a utility under the Utilities\ directory called "Analyzer.exe" but all it ever spits back when run is the text "Invalid". I have no idea what Analyzer.exe does anyway, so messing with it (or even focusing on it) is probably a bad idea.
Effectively what you want is a utility that limits the LBA ranges that TRIM applies to (e.g. doing them in very small batches over time, rather than a large LBA range all at once). I know Linux can provide something like this (search Google for "wiper.sh") and FreeBSD could as well (but we don't have the ability for userland applications to get a list of cylinder groups which have been free'd by the filesystem, so right now the kernel does TRIM itself, and in a very sub-optimal way (see links below).
Relevant FreeBSD thread where the methodology used has come under scrutiny:
http://lists.freebsd.org/pipermail/freebsd-fs/2011-April/011341.html http://lists.freebsd.org/pipermail/freebsd-fs/2011-April/011341.html
http://lists.freebsd.org/pipermail/freebsd-fs/2011-April/011345.html http://lists.freebsd.org/pipermail/freebsd-fs/2011-April/011345.html
http://lists.freebsd.org/pipermail/freebsd-fs/2011-May/011360.html http://lists.freebsd.org/pipermail/freebsd-fs/2011-May/011360.html
http://lists.freebsd.org/pipermail/freebsd-fs/2011-May/011362.html http://lists.freebsd.org/pipermail/freebsd-fs/2011-May/011362.html
Possibly the Intel SSD Toolbox utility could offer something similar ("gradual" TRIMming rather than all-at-once).
Also, are you sure you 4K-aligned your partitions on the SSD drive, re: performance concerns? Just making sure. I imagine you have, but wanted to ask anyway. (I'm also a little surprised you're using XP Professional in what sounds like a commercial/borderline server-esque environment; don't worry, I have nothing against XP Pro (I use it happily on my home workstation) but given your work model I'm surprised...)
05-04-2011 10:55 AM
Haven't run any alignment tools yet, but really haven't had any problems yet either. When we would config our striped raids, we would set block size at 4kb since the machines ingest so many small files. What kind of performance gain can we get from running a tool such as Paragon's Alignment tool?
We use XP Pro mostly because it's been very stable & cost effective when the ingesters were setup. The downside has been the connection limit on mapped drives, with the number of renderers tapping the ingesters. We've been adding ingesters as needed to accomodate.
I spoke with the ingester software developers, & they said they would write something for the service that would shut it down for a brief period & fire off the optimizer then wait for a status return before firing off the service. I told them there was no command line option for the optimizer & they said "Oh... why not?"
Seems too reasonable to me. How difficult would it be for Intel to put a command line option together?
05-04-2011 05:38 PM
I will foward the suggestion to Intel for command line options for the SSD Optimizer.
05-04-2011 07:38 PM
When you say "block size at 4KBytes", are you referring to the RAID (presumably RAID-0) stripe size, or are you referring to the NTFS filesystem cluster size? They're two completely unrelated things.
RAID-0 stripe size defines how much data is written to each member of the array at once. Example: two disks in a RAID-0 array, with stripe size of 32768 bytes. This would result in drive 0 getting 16KBytes of data written to it, and drive 1 getting 16KBytes of data written to it. Stripe size doesn't matter with RAID-1 because there's no striping. RAID-5, same thing. Trust me on this, this is how it works. Don't believe nonsense like what you might see on Youtube below (the individual describing it gets "most" aspects of RAID correct, but he's absolutely wrong in how the data gets written to the physical disks):
http://www.youtube.com/watch?v=RYBtmVMtH1g http://www.youtube.com/watch?v=RYBtmVMtH1g
A much better visual diagram (read the image caption very slowly and carefully) is here:
http://www.pcguide.com/ref/hdd/perf/raid/levels/singleLevel0-c.html http://www.pcguide.com/ref/hdd/perf/raid/levels/singleLevel0-c.html
NTFS cluster size is how many blocks (in bytes) to allocate per file. E.g. if you choose a cluster size of 16KBytes and you write a file to the disk that is only 500 bytes in size, on the *actual filesystem* the file takes up 16KBytes. A larger cluster size can result in improved performance when very large files are used. Using a benchmarking tool like ATTO can help determine what the "optimal" cluster size is. On XP, NTFS filesystems default to 4096 byte clusters. I tend to use that for my OS disks, but increase the cluster size on my storage disks (filled with movies, games, etc.) to 32KBytes solely since there's a performance gain.
More importantly, neither stripe size nor NTFS cluster size has anyhing to do with partition alignment.
Partition alignment defines which LBA offset an NTFS/FAT32/FAT/ext2fs/ext3fs/FreeBSD slice starts at. You can't start at LBA 0 because that's reserved for OS bootstraps and the MBR/PBR, and there are blocks after LBA 0 which are also used for bootstrapping (usually the OS bootloader). Most people use an offset of 128 (e.g. 128*512 = 65536, or 64KBytes, which is 4K-aligned), which is enough for the "stage 0" and "stage 1" bootstraps (enough to figure out how to load things like NTLDR off a filesystem, etc.). Compare that to what XP might pick when creating a partition on its own (could use offset 37 for example; 37*512 = 18944. 18944 / 4096 = 4.625, which means it's not 4KByte aligned, thus performance hit). Make sense?
Think of SSD flash like RAM; memory has to be aligned in what's called "pages" (usually 512 bytes, 4096 bytes, 64KBytes, or 2MBytes for superpages; I think there's even larger). Non-aligned allocation within the kernel results in *really* bad system performance, so that's why the kernel manages memory in pages. CPUs also require this aligned paging. Remember: I'm talking about RAM/memory here and not SSDs, but the *concept itself* is the same.
There are SSD benchmarks all over the web showing what the performance difference is between a non-4K-aligned partition and an aligned partition. There's quite a substantial difference (almost double in some cases). I urge you to use the resources available to you to find evidence for yourself -- it's an educational process. 🙂
I cannot comment on "Paragon's Alignment Tool" because I've never used it; I use DISKPAR (not DISKPART) to partition an SSD first. OCZ has a topic on how to do this. You can accomplish the same using DISKPART but the syntax/user interface is very different.
Finally, be aware that overall Windows 7 offers significant improvements with SSDs that XP simply does not have. Am I telling you to upgrade to Windows 7? No (example: I myself don't run it!). I'm saying that W7 supports native TRIM (e.g. no need to run the Intel SSD Optimiser; W7 takes care of all of this at the NTFS and storage controller driver layer). Just a point worth considering.
Hope this helps, or at least is educational. There's so much misinformation on the 'net about all of this because everyone and their dog thinks they're a "tech whiz" when in fact only some people truly understand storage technology.
05-05-2011 12:16 PM
Thank you guys for the valuable input. We went ahead & purchased Paragon's Disk Alignment Tool & ran it on one of the newer 320 series 40gb drive, then transferred the data off the X-25 value drive to the 320 series & swapped it out. The ingester seems very happy & dead on schedule. I wrote a script in the scheduler software to shutdown the service, fire off the toolbox executable, run optimization through the gui, then restart the service. A kluge no doubt, but it works. Again, thank you kindly. -jw
