Restoring 160GB G2 drive to factory state - Full, quick format or HDDErase 3.3?
03-15-2010 02:33 AM
I'm intending on reducing my SSD size to 144GB to gain claimed 2.8X endurance improvement by having 10% more spare space.
I need to choose the solution to erase the drive before repartitioning.
Which is the best:
- full format (from other OS booted drive)
- quick format
- Using HDDErase 3.3. tool
03-15-2010 11:54 AM
The best method of restoring your SSD to the factory default state is to use the ATA "Secure Erase" command. Unfortunately, it's not simple to figure out what commands are actually being done by Windows or various drive tools.
Regarding the potential 2.8X endurance increase, I recommend you read a similar thread:
/thread/11591?tstart=30 http://communities.intel.com/thread/11591?tstart=30
Hope that helps.
03-15-2010 04:53 PM
From what I've read there, there is no real use in this method?
03-15-2010 05:22 PM
To summarize the other thread:
The endurance benefit from reducing capacity is a function of the write amplication that the drive is seeing. For a normal client usage model, the write amplication is already quite low, so there will be smaller endurance increase. But the benfits for an enterprise server usage model can be significant.
03-16-2010 01:01 AM
Exactly as I got it. Thanks for assistance.
