Problem with SSD toolbox
I am trying to use the toolbox for the first time. But I already get stuck trying to select my SSD. All itt does is constantly refresh. My SSD is an 80GB Gen1 - could that be the problem? The OS is Windows7 X86. Here is the first screen that shows my SSD as first drive.
5 REPLIES 5
The SSD Toolbox should run fine. However, the SSD Optimizer only supports G2 and newer drives.
Thank you for the answer. That is kind of what I suspected. I wanted to "clean" my SSD. Can you recommend how to go about that. I have two of those Gen1 models and since there is no Trim, they must be "clogged". Your guidance would be appreciated.
I have the same problem but with a brand new 510 drive. Everytime I click on the SSD drive it refreshes the screen. I can click on the two SATA drives just fine.
Whats happening?
I have the same problem with my new 320 series.
