09-28-2009 05:42 PM
I have a Intel X25-M SSDSA2MH080G2C1 2.5" 80GB. I believe partition alignment to the nand block size is important for performance on SSD's. What is the nand block size on this drive? How can I check that the partition is aligned properly?
09-29-2009 02:14 AM
Hello!
The NAND erase blocks on Intel MLC drives are 128 pages wide. With each page being 4kB in size this results in a block size of 512kB. So, with either 0.5MB or the more widely used 1MB offset (Win7 etc.) your partitions will be aligned to the block size!
10-01-2009 06:40 PM
Thanks for the reply. My partiton was misaligned as I had copied the partition to the SSDs with Acronis from a Dell PC which had a restore/utility partition. I fixed the alignment and got a good increase in performance as you can see.
Before
After
