Note from Intel NAND Solutions Group - Intel® SSD Toolbox with Intel® SSD Optimizer and latest firmware are here!
10-26-2009 01:39 PM
We're excited to announce the Intel® Solid-State Drive Toolbox, with Intel® SSD Optimizer and firmware update, designed for our 34nm Intel® X25-M Mainstream SATA SSDs. The latest tools are designed to help better manage and retain the out-of-box performance of Intel SSDs.
For 34nm X25-M & X18-M 160GB owners, the firmware update also offers a performance boost to sequential write speeds by delivering up to 100MB per second, a 40 percent performance improvement over the existing firmware version.
The Intel SSD Toolbox allows users to more effectively monitor and manage the SSD's health. The firmware upgrade and Intel SSD Optimizer use the Windows* 7 ATA Data Set Management Command (known as Trim) to help keep the Intel SSD running at continued high performance. In addition, the SSD Toolbox and Optimizer also allow the respective enhancements to work with Windows* XP and Vista* operating systems.
The Trim attribute synchs the operating system's view of deleted files with those that are deleted, but not erased on the drive. Trim tells the SSD which data blocks are no longer in use. This helps stabilize the performance and health of the SSD over time.
The Intel SSD Toolbox provides SSD management tools and information about the drive, including comparing Self-Monitoring and Reporting Technology (S.M.A.R.T.) drive attributes to manufacturer threshold. It provides basic and full diagnostics, along with recommended actions. The Toolbox also features a graphical user interface that will allow end users to schedule and run the Trim command independent of the operating system. Intel recommends users install the firmware update and toolbox, and run the Trim function daily which can be scheduled automatically from the SSD Optimizer tool..
The firmware upgrade can be found at http://www.intel.com/go/ssdfirmware www.intel.com/go/ssdfirmware and the Intel SSD Toolbox and Optimizer at /www.intel.com/go/ssdtoolbox www.intel.com/go/ssdtoolbox.
We will be monitoring this blog and will try to answer questions that you may have. Enjoy the latest software!
NAND Solutions Group Marketing team
10-27-2009 03:02 PM
Redux's quote is accurate. We are investigating. The site has temporarily taken down and we will get back with updates asap.
Regards,
Brady - NAND Solutions Group
10-27-2009 03:32 PM
Thank you, folks.
Take your time Brady. Just do it right, I'd like not to loose my ssd.
11-09-2009 10:41 AM
Hey Brady,
Do you guys happen to have any updates concerning the rerelease of the firmware and/or the optimization software?
10-27-2009 05:27 PM
I spoke with Intel this evening and they acknowledged the broken link and advised that it should be fixed within a couple of hours. However, given the issue with the first version of the firmware (drive password protection causing data loss which ultimately resulted in the last-minute delay of the G2) and now this, I may hold off for a week or two to make sure it's stable before I flash the ROM. I'm guessing they pulled it on purpose.
Early adoption has associated risks -- I can live without TRIM (and the reported read/write speed increase) for another couple of weeks. This drive is already ridiculously fast as-is.
10-28-2009 08:17 AM
There's a problem with the new firmware:
/message/71383# 71383 http://communities.intel.com/message/71383# 71383
http://www.hardforum.com/showthread.php?t=1463671 http://www.hardforum.com/showthread.php?t=1463671
