Matrix Storage RAID Question
11-19-2009 12:23 PM
Hi all - A little confused here -
First - I have 82801JR (ICH10R) controller that isn't listed in the Matrix storage download list. Am I supported or not?
Second, should I use the RAID 0 on the motherboard or the IMSM?
Third, I have a X25M coming soon. When I set it up, should it be configured as IDE/AHCI? When I do that, and if IMSM works with my computer, would I then be able to add another drive to it at a later date and support RAID 0?
11-19-2009 02:04 PM
Here are my answers:
First: Yes
Second: You should create your RAID0 by using the RAID utility, then install the OS by loading/integrating the needed Intel RAID driver (IMSM or ISRT).
Third: As long as you have just 1 SSD, you should run it in AHCI Mode. If you would buy a 2nd SSD later, you will be able to create a RAID0, but I recommend to take the new Intel(R) Rapid Storage Technology (IRST) drivers and not the IMSM ones (much better performance).
11-19-2009 03:54 PM
ok, so setup with AHCI mode, get the Intel(R) Rapid Storage Technology later on when a 2nd drive comes along and all will be good.
Thanks for helping me out!
Jeff
