Intel X25 M and Toolkit 2.0 can't run Optmizer
Hi , I have a Intel SSD 25M 80 GB G2 with firmware n° 2CV102HD but, when I lunch Toolkit 2.0 at tool "Intel SSD Optmizer" a raccomandid Action apper in red : "The VSS service is disable. The Intel SSD Optmizer requires the VSS service to be enabled to function property. See user guide for more information".
I'm working on XP SP3 .
What can I do to run the optmizer properly ?
6 REPLIES 6
And after just checking it corresponds with the "Volume shadow copy" as well...
ok run regedit.exe and find this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\VSS
Change "Start" to a value of "2" and reboot.
If this does not work your OS is corrupted for you not to see or start this service and you will have to reinstall.
GREAT !!! YOU ARE A TRUE "SNIPER" !
THANK'S A LOT!
LUCA from Italy
