Intel 520 - Password not accepted after restart
I installed new Intel 520 SSD into my T420s and it works great with one exception - HDD password configured in BIOS is not accepted after restart. Both user and master passwords were configured for the drive but none is accepted after restart.
There is no issue with password when laptop is powered on or resumed from hibernation.
I had Intel 320 SSD before and it worked correctly in the same setup.
Thank you for help
René
9 REPLIES 9
Since it does it under Windows and Xubuntu the problem is in the computer's BIOS.
The BIOS is locking the drive and then asking for a password on a warm boot. Once the BIOS sends the lock command to the drive it will not respond to much of anything unless the power is cycled. So the BIOS locks the drive, then sees that the drive requires a password, and send the password to the drive. But the locked drive will not unlock unless the power is turned off and back on even with the correct password. The drive locking of this type is supposed to do that, but the BIOS is messing everything up.
So the BIOS is definitely weird there. Hopefully there is an update for it.
The BIOS should not send the lock command to the drive. Normally once the drive is powered up and has a good password, you should never have to reenter the pass and nothing should be locking the drive. But the BIOS is programed wrong for encrypting drives. It would be interesting to see if it does that with a standard drive too. But they should not have the high security locking that encrypting drives do so it is probably just an issue with drives like the 520. The BIOS maker never tested the BIOS on a high security drive...
Here is an article about the drive parameters in question:
https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase ATA Secure Erase - ata Wiki
Step 1a - Ensure the drive is not frozen:
Security:
Master password revision code = 65534
supported
not enabled
not locked
not frozen
not expired: security count
supported: enhanced erase
2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
If the command output shows "frozen" (instead of "not frozen") then you cannot continue to the next step.
Many BIOSes will protect your drives if you have a password set (security enabled) by issuing a SECURITY FREEZE command before booting an operating system. If your drive is frozen, and it has a password enabled, try removing the password using the BIOS and powering down the system to see if that disables the freeze. Otherwise you may need to use a different motherboard (with a different BIOS).
A possible solution for SATA drives is hot-(re)plug the data cable (this might crash your kernel). If hot-(re)pluging the SATA data cable crashes the kernel try letting the operating system fully boot up, then quickly hot-(re)plug both the SATA power and data cables.
  • It has been reported that hooking up the drive to an eSATA SIIG ExpressCard/54 with an eSATA enclosure will leave the drive security state to "not frozen".
  • Placing my system into "sleep" (Clevo M865TU notebook) worked too---and this may reset other drives to "not frozen" as well. This also worked on my Lenovo Y580 with a Mushkin mSATA.
  • Users have also reported that IDE Drives may be unfreezed by plugging in an IDE cable to a CD-ROM first, booting your system and then moving the IDE cable to the drive in question. This will allow you to bypass "SECURITY FREEZE" commands sent by BIOS and your OS. BE AWARE, that IDE cables are not hot-pluggable and this technique possesses even higher risks; under no circumstances should you connect/disconnect/swap power cables of an HDD or CD-ROM, when your PC is on.
So your BIOS is sending the "SECURITY FREEZE" the the drive. The ATA wiki article is pretty technical but ti does show all the horrible basics of what is going on there. Unfortunately, there is nothing you can do about it short of getting a fixed BIOS update.
That makes sense and I agree that it is probably the BIOS at fault. However, the OP states that an Intel 320 SSD in the same setup worked correctly without this problem with the same BIOS. The problem seems to be unique to the combination of a ThinkPad BIOS and the 520 SSD.
Oh!
So the firmware on the 320 and 520 drives might be different. I see they all say "400i" but there may be a dozen version of this 400i firmware too... I pulled the HD info off a 520 I had here and got the following:
mint@mint ~ $ sudo hdparm -I /dev/sdc
/dev/sdc:
ATA device, with non-removable media
Model Number: INTEL SSDSC2CW120A3
Serial Number: CVCV223301VR120BGN
Firmware Revision: 400i
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
Used: unknown (minor revision code 0x0110)
Supported: 9 8 7 6 5
Likely used: 9
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 234441648
LBA48 user addressable sectors: 234441648
Logical Sector size: 512 bytes
Physical Sector size: 512 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 114473 MBytes
device size with M = 1000*1000: 120034 MBytes (120 GB)
cache/buffer size = unknown
Nominal Media Rotation Rate: Solid State Device
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 128
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
* Security Mode feature set
* Power Management feature set
* Write cache
Look-ahead
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
* 48-bit Address feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* 64-bit World wide name
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* unknown 76[14]
* DMA Setup Auto-Activate optimization
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Data Tables (AC5)
* Data Set Management TRIM supported (limit 1 block)
* Deterministic read data after TRIM
Security:
supported
enabled
locked
not frozen
Security level high
4min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5001517bb296403c
NAA : 5
IEEE OUI : 001517
Unique ID : bb296403c
Checksum: correct
mint@mint ~ $
The
is interesting. I wonder how this compares to the 320 drive...
There is also the update tool:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 Download Center
But that might install different software for different drives too. Perhaps the toolbox application will give more info on the drive firmware and help see what the differences actually are.
I note that Toolbox version v1.93 was released far after OP's post. Aug. 17 vs. Nov. 27th. Who knows, maybe updating the 520's firmware to the latest version will fix it all. They list a lot of firmware revisions here:
<a href="http://downloa...
I can confirm that the same issue occurs with the T420 and T430 on both Intel 520 SSDs and the Intel 330 SSD (which is not a self encrypting drive). Trying to work with Lenovo to see if they can release a BIOS update that would fix this issue.
CSupp4
Problem still exists on my Lenovo T530 with latest BIOS 2.63 from 2015 and Intel 520 SSD.
