08-08-2011 04:36 PM
I just built a system on an Asus P8Z68 Deluxe motherboard that includes two Intel 510 256Gb drives. One is drive C and the other is drive D on ports 0 and 1 respectively of the Intel controller. I am not using the Marvell controller. I was dissapointed in the Primary Drive WEI score so I opened the Intel RST Management panel and noticed the C drive is reporting a SATA Transfer Rate of 3Gbs while the D drive is reporting a 6Gbs transfer rate. The only difference between the two drives is the C drive is running the PWG2 firmware while the other one is running the PWG4 firmware. Does anyone have any thoughts on what may be holding this drive back?
08-08-2011 04:40 PM
Sounds relevant:
/thread/23608?tstart=30 http://communities.intel.com/thread/23608?tstart=30
Also, the Windows Experience Index means absolutely nothing. You shouldn't bother to base anything on that number; the number means nothing, quite literally.
08-08-2011 06:15 PM
It was me who started the other thread on the almost identical topic (/thread/23608?tstart=30 http://communities.intel.com/thread/23608?tstart=30). It looks like we have exactly the same problem and indeed by doing a complete shutdown and cold start the problem goes away. At least until you reboot!
I tried using Intel's "chat" system to report it but that was utterly useless and despite promising to pass it on to someone who could help (as they certainly could not) I never heard anything back. I then tried their e-mail support and got nothing but an acknowledgement. So I phoned their expensive phone number and finally the ball started to roll. They asked for all sorts of information - VAT invoice from the supplier, a number from the casing (as they weren't interested in the serial number that their own tool reported) which meant taking the system to pieces. Anyway, they said someone would get in touch and I now seem to have some kind of case ID. My Intel ref is 8000290527 so if you do manage to get through to them tell them that and it may get them more interested.
I also have the same situation of one firmware being PPG2 and the other PPG4 (mine seems to be "PPG" and yours is "PWG"?) and when I asked about this during the "chat" they said that both firmwares were the latest and the different numbers referred to revisions. In that case I would say the later revision is the newer firmware but they didn't seem to get that. Maybe this is the problem? I used to have reboots that gave me one drive at 6gb/s and the other 3gb/s but lately they both seem to go to 3gb/s after a reboot.
Well, I suggest you call Intel and get a case going and if I hear anything from them I'll post it here. It's good to see it's not a motherboard thing so in my case they can't shift the problem to Dell which I'm sure would have been the first trick they would have tried! Let me know if you make any progress/discoveries too.
08-08-2011 06:17 PM
You can run WEI on command line to see the underlying benchmarks to isolate the problem: http://technet.microsoft.com/en-us/library/cc770542%28WS.10%29.aspx http://technet.microsoft.com/en-us/library/cc770542%28WS.10%29.aspx
I'll follow up with Intel on this curious SATA mode issue.
08-08-2011 06:42 PM
Many thanks - I've got a case reference number (8000290527) but it seeems I have to take my system to pieces again as they need me to check another number printed on the drive itself!
I also notice that when I benchmark these 2 drives, one is significantly faster than the other in the first part of the benchmark (420mb/s vs 372 mb/s). I have the trim tool scheduled to run once a day but this hasn't levelled out their speeds although I don't suppose it is meant to. The one with firmware PPG2 gets better results and benchmarks using ATTO show the same difference between the drives. I've run the different benchmarks many times on different days and the difference always shows up.The drives are in AHCI mode and the CrystalDiskMark benchmarks are shown below:
Please let me know if you find anything out.
