07-20-2011 02:43 AM
I have a problem with Intel 320 80GB. Several times I have had system freezes (from 10sec to 30sec). I own drive from two months.
I'm using linux.
DMESG:
http://shorttext.com/TyBZxD http://shorttext.com/TyBZxD
hdparm -I
http://shorttext.com/EAfvZ1 http://shortText.com/EAfvZ1
fdisk -l
/dev/sda1 * 1024 41945087 20972032 83 Linux -- xfs
/dev/sda2 41945088 46140415 2097664 82 Linux swap / Solaris/dev/sda3 46140416 156301311 55080448 5 Ext/dev/sda5 46140448 47779839 819696 83 Linux -- reiser/dev/sda6 47779872 51975167 2097648 83 Linux -- reiser/dev/sda7 51975200 156301311 52163056 83 Linux -- ext4 with discard (TRIM)
smartctl
http://shorttext.com/jxBTik http://shortText.com/jxBTik
Controller
00:05.0 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
I tried with other SATA cable, didn't help.
Any help please.
07-20-2011 06:50 AM
Drive looks to be in perfect health according to all of the SMART attributes. Your issue is probably due to daemons running on Linux in the background which are doing I/O to your drive. dmesg, smartctl, df, etc. aren't going to help diagnose this. Things like sar or iostat or top -b in a while loop logging to a file might. Furthermore, you should investigate TRIM support on Linux -- it is something you do have to turn on, if I remember right (I'm a FreeBSD guy, not Linux).
07-20-2011 09:42 AM
usr wrote:
Controller
There's your problem. There are compatibility issues between nvidias fake-AHCI and SSDs. The usual solution is to run the controller in IDE mode and make sure to disable Command Queueing in the driver. How you would do on Linux I have no idea.
07-21-2011 01:01 PM
Thanks for replies.
I'll check the TRIM.
Two years ago I had a Kingston SNV125-S2/40GB with Intel's hardware inside but without TRIM support and that issue didn't occur... (the same controller and operating system). What do you think now ?
Maybe it's elevator=noop ?
cat /sys/block/sda/queue/scheduler
[noop] deadline cfqI'll check it too.
Beside I forgot to write about the scenerio this issue. It happens (rarely but...) when I unpacking kernel or installing compiled app/package.
