09-14-2011 01:55 PM
I have an Intel 320 80gb on Windows 7. I have upgraded to latest firmware, but am concerned about getting the infamous 8mb bug.
Does anyone know if emabling the Windows drive settings of: "Better Performance" and "Enable Write Caching" increase the likelyhood of getting the 8mb bug upon a power failure or system freeze/forced shutdown? (they are currently enabled by default).
Thanks!
09-14-2011 02:44 PM
I doubt that anybody knows the true cause of the 8mb bug (not even intel engineers).
But anyway, Windows 7 should automatically optimize settings for SSD (disable defrag, turn off indexing, enable trim, etc), so all you need to do is run WEI.
here's how:
http://windows.microsoft.com/en-US/windows7/What-is-the-Windows-Experience-Index http://windows.microsoft.com/en-US/windows7/What-is-the-Windows-Experience-Index
edit: fixed link. gave vista instruction by mistake.
09-20-2011 12:46 PM
Intel engineers must know the cause of the 8MB bug.... how else would they be able to issue a firmware to fix it?
