06-26-2011 03:21 AM
I recenlty bought an Intel 320 SSD with 120GB capacity. I already had an Intel X-25M G2 80GB Postville SSD drive with Windows 7 Ultimate 64bit installed on it. I used the Intel Data Migration tool (powered by Acronis) and I cloned them.
Although my previous SSD (the 80GB one) had a Windows 7 score of 7.8 points, my new one (which I think should be faster) is slower, rating 7.6 on Windows 7 Rate Assesment.
And my question of course is ... WHY.. ?
I bought this SSD cause its faster right?...
Thank you in advance.
06-28-2011 09:54 AM
Another option is to run "winstat" on command line. This program is the basis of WEI.
For example, you can check how Windows is benchmarking your C: disk with: "winsat disk -drive c"
http://technet.microsoft.com/en-us/library/cc770542(WS.10).aspx http://technet.microsoft.com/en-us/library/cc770542(WS.10).aspx
06-27-2011 10:27 PM
http://www.attotech.com/products/product.php?sku=Disk_Benchmark ATTO Disk Benchmark provides even more detailed information. You can download it from other sites without the need for registration.
06-28-2011 09:54 AM
07-04-2011 12:32 PM
I run winsat and these are the results. Your opinion?
I have to tell you again that my system is cloned via Intel SSD Migation tool. So the "system" partition (which it was 100MB) now is 150MB. I dont know if it has to do with my "problem". Overall the system is very responsive and fast ofcourse. My motherboard is an Asus Maximus Formula X38 intel chipset.
07-06-2011 08:54 AM
Nothing looks odd.... Can you run winstat for the X-25M? It just be a difference on how MS weights the values.
Intel 320 160GB vs X25-M 80GB: http://www.anandtech.com/bench/Product/370?vs=125 http://www.anandtech.com/bench/Product/370?vs=125
07-06-2011 02:00 PM
Hmmm... I erased my Intel 80GB X-25M so I cannot run winsat to it... .Sorry.
But let's say that I am very sattisfied with the Intel 320 120GB after all.
Thank you guys for your support!
