Cristl disk info ssd index?
05-25-2010 05:26 AM
I have Intel X25-M G2 80Gb ssd just 3 weeks old. I have installed Windows 7 and ssd toolbox.
Till yesterday Cristdisk info show me that my ssd 100%good. today the index drop on 99% good.
I have no reason for this situation.
The counter says :
Power on 200h
Host writes 580Gb
Trim is on.
My question is: why this happend?
If I use erase ssd does this menas that ssd disk fitness will return to 100%.
Thank you.
09-30-2010 09:18 AM
Hello, this is not an issue especially if you copy a big piece of information, I suggest you to install the latest version of the SSD toolbox version 2.0 and run the Intel SSD Optimizer and the System configuration tuner to keep the SSD in good shape.
09-30-2010 11:52 AM
This is normal, the Intel G2 series can only endure 35TB writes in total, after it dies.
Because you have written 580GB, the drop to 99% is normal.
Mauriceb, please correct me if I'm wrong.
09-30-2010 01:32 PM
Hello, actually let me tell you that this information is not correct, here you have the normal burn-in range and cycles of Intel® High Performance Solid State Drives:
Tested to burn in Range of 15 hours and 22 times turn on/off
The following data applies to all Intel® High Performance Solid State Drives
All Intel® High Performance Solid State Drives undergo quality test prior to release from factory.
Normal Range for 80GB: Up to ~20 hours burn-in. Up to ~25 cyclesNormal Range for 160GB: Up to ~40 hours burn-in. Up to ~25 cycles
