Intel X25-E Failures
Anyone having problems with X25-E reliability? We bought ten drives and put 8 of them into a RAID array, and over the past month two of them have failed. One could be a fluke, but two out of ten seems like a really high failure rate in a month.
8 REPLIES 8
That does seem like an extraordinarily high failure rate. I have had 4 in RAID 0 since shortly after they were released without any problems. I have not seen people posting reviews noting any failures so far. I hope Intel is taking care of you on the warranty.
Can you tell us the serial numbers of failed drives?
Does it Intel chipset based RAID or not?
If yes then /thread/5036?tstart=0 http://communities.intel.com/thread/5036?tstart=0 possible reason of failures
if not I still need the serials
Sent them back to NewEgg already. I have the serial numbers for the other drives in the shipment... might be from the same batch if that would be helpful.
