Intel 320 SSD on Linux, write wear indicator, smartctl
Hi All,
I am burning in a new Intel 320 SSD on Linux for use with a database, and the write wearing is something I would like to verify and make sure it fits with our write capacity requirements. I am trying to grok the smartctl output here below, but don't know what to look at that would tell me how many writes the MLC has taken and how much is left. Given the docs on the SMART output for the 320 I suspect its in the unknown attributes but not sure.
Regards,
Josh
320 Series SSDSA2CW300G3 MLC Solid State Drive
# smartctl -a /dev/sde
smartctl version 5.38 [x86_64-redhat-linux-gnu] Copyright (C) 2002-8 Bruce AllenHome page is http://smartmontools.sourceforge.net/ http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: INTEL SSDSA2CW300G3Serial Number: CVPR111002XL300EGNFirmware Version: 4PC10302User Capacity: 300,069,052,416 bytesDevice is: Not in smartctl database [for details use: -P showall]ATA Version is: 8ATA Standard is: ATA-8-ACS revision 4Local Time is: Wed Apr 13 17:41:13 2011 UTCSMART support is: Available - device has SMART capability.SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled.Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run.Total time to complete Offlinedata collection: ( 1) seconds.Offline data collectioncapabilities: (0x71) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported.SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer.Error logging capability: (0x01) Error logging supported. General Purpose Logging supported.Short self-test routinerecommended polling time: ( 1) minutes.Extended self-test routinerecommended polling time: ( 1) minutes.Conveyance self-test routinerecommended polling time: ( 1) minutes.SCT capabilities: (0x003d) SCT Status supported. SCT Feature Control supported. SCT Data Table supported.
SMART Attributes Data Structure revision number: 5
Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 3 Spin_Up_Time 0x0020 100 100 000 Old_age Offline - 0 4 Start_Stop_Count 0x0030 100 100 000 Old_age Offline - 0 5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 117 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2170 Unknown_Attribute 0x0033 100 100 010 Pre-fail Always - 0171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0184 Unknown_Attribute 0x0033 100 100 090 Pre-fail Always - 0187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 2225 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 16048226 Load-in_Time 0x0032 100 100 000 Old_age Always - 36227 Torq-amp_Count 0x0032 100 100 000 Old_age Always - 48228 Power-off_Retract_Count 0x0032 100 100 000 Old_age Always - 269162232 Unknown_Attribute 0x0033 100 100 010 Pre-fail Always - 0233 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0241 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 16048242 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 18807
10 REPLIES 10
The version of smartmontools you are using is *significantly* old. It has no knowledge of SSDs, and thats proven by the "Not in drive database" message at the top. It's incredibly important that people using SMART utilities understand in full the data they're looking at, and take the time to read every single line and *understand* those lines. The same advice goes for people who stare at RAW_VALUE and think it's a 1:1 counter; it's not.
Please upgrade to smartmontools 5.40 or (better) 5.41 (development) and then provide the output here. We can talk about the results after you do that.
WFisc1
There are various values you can use for this.
See details in http://download.intel.com/design/flash/nand/325170.pdf http://download.intel.com/design/flash/nand/325170.pdf (page 7) - the following infos are from this PDF:
Timed Workload Media Wear Indicator — ID E2h (226 in smartctl output):
This attribute tracks the drive wear seen by the device during the last wear timer loop, as a percentage of the maximum rated cycles. The raw value tracks the percentage up to 3 decimal points. This value should be divided by 1024 to get the percentage.
For example: if the raw value is 4450, the percentage is 4450/1024 = 4.345%. The raw value is held at FFFFh until the wear timer (attribute E4h) reaches 60 (minutes). The normalized value is always set to 100 and should be ignored.
Timed Workload Host Reads Percentage — ID E3h (227 in smartctl output):
This attribute shows the percentage of I/O operations that are read operations during the last workload timer loop. The raw value tracks this percentage and is held at FFFFh until the workload timer (attribute E4h) reaches 60 (minutes). The normalized value is always set to 100 and should be ignored.
Workload Timer — ID E4h (228 in smartctl output):
This attribute is used to measure the time elapsed during the current workload. The attribute is reset when a SMART EXECUTE OFFLINE IMMEDIATE (D4h) subcommand 40h is issued to the drive. The raw value tracks the time in minutes and has a maximum value of 232 = 4,294,967,296 minutes (8,171 years). The normalized value is always set to 100 and should be ignored.
In the PDF you find on page 9 details on how to calculate the drive wear.
best regards,
Werner
WFisc1
Just a remark:
226 Load-in_Time 0x0032 100 100 000 Old_age Always - 36 -> 0.03515625 %227 Torq-amp_Count 0x0032 100 100 000 Old_age Always - 48 -> 48% read percentage228 Power-off_Retract_Count 0x0032 100 100 000 Old_age Always - 269162 -> in minutes -> 4486 hours 2 minutes -> 186 days 22 hours 2 minutes
For value 228 you maybe have to substract 65535 before (see below). Then it would be 203627 minutes -> 3393.78 hours -> 141.4 days
Not sure if this could be true. To be sure, better update smartctl as mentioned by koitsu
My 320 Series SSD with 160 GB had the following values when it was brand-new (I did not issue a single I/O before querying the SMART values here):
root@ubuntu-10-10:~# smartctl -A /dev/sdb
smartctl 5.40 2010-03-16 r3077 [x86_64-unknown-linux-gnu] (local build)Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net http://smartmontools.sourceforge.net
SMART Attributes Data Structure revision number: 5Vendor Specific SMART Attributes with Thresholds:ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 3 Spin_Up_Time 0x0020 100 100 000 Old_age Offline - 0 4 Start_Stop_Count 0x0030 100 100 000 Old_age Offline - 0 5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3170 Unknown_Attribute 0x0033 100 100 010 Pre-fail Always - 0171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1225 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 5226 Load-in_Time 0x0032 100 100 000 Old_age Always - 65535227 Torq-amp_Count 0x0032 100 100 000 Old_age Always - 65535228 Power-off_Retract_Count 0x0032 100 100 000 Old_age Always - 65535232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 5242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 12
You do not have to subtract 65535; I'm not sure what gives you that idea. 🙂
65535 is the default power-on/reset value for the attribute. After about 30 seconds of I/O the attribute should increment to zero (65535 -> 0) and work fine after that. This can be reproduced by resetting attributes 226/227/228 to factory defaults by doing "smartctl -t vendor,0x40 /dev/disk".
To the OP and Werner: smartmontools 5.41 is out (non-development), and has appropriate SSD support for the newer (320, 510, etc.) Intel-series SSDs. Attributes will be properly labelled.
