incomplete downloads filling ssd up
I have been downloading huge files and for some reason my computer shuts down before they are finished and they are filling up my 80 gb ssd How can I delete them can't even find them
1 REPLY 1
MBall5
Contributor
Hello, I recommend you to download the toolbox v2.0 from the following link:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng
once you install this toolbox I suggest to run under: Intel® Solid State Drive Management Tools: Intel® Solid State Drive Optimizer and System Configuration Tuner this should help with this problem.
If the issue persist I suggest to perform a secure erase (please back up your information since all the content of the Solid State Drive will be erased) then try to test the Solid State Drive again.
Also feel free to contact the Intel® Solid State Drive support at the following phone number: 916 377700 option 6.
