06-14-2013 04:41 PM
mHey intel community!
When I do a diagnostic scan in my SSD tool, it tells me that I have data integrity problem at 64% is there any help or tool to fix this? or is this the end of my SSD? I have problems to get a fresh install of windows 7 to work.. because I get "memory management bluescreens" and wierd errors while completing windows updates. for example: it's not possible to finish the service pack 1 update.I'm still searching for the source of the error, because I'm not sure if it's my SSD or my RAM.
smart tool details:
functionality - goodremaining life time - about 98%power-on hours count: 6418all options there are green and ready
data integrity problem at 64% (in quick and detailed mode)I'm not sure that all translations are correct, because I'm from germany
but if you can help me in any way.. you're welcomegreetings daen
06-17-2013 08:51 AM
Hello Daen,
Just to clarify Windows* 7 has a memory diagnostic tool (RAM); however, due to the results obtained from the Intel® SSD Toolbox's diagnostic test I would recommend to contact your local Intel® SSD support team for a possible warranty replacement.
http://www.intel.com/p/en_US/support http://www.intel.com/p/en_US/support
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Please also note the Intel® SSD Toolbox uses the operating system default language.
