Will the D7-P5520 7.68TB drive work in a poweredge r630
cdml
We have an older Dell PowerEdge R630 with an 8 hot-swap drive cage and a PERC 730H RAID controller. Will we be able to use 6 x D7-P5520 7.68TB drives to create a 38TB RAID5 array. Are these drives compatible with the PE R630/PERC 730H combination?
Thank you,
Len Kaplan
1 REPLY 1
SolidigmYordan
Moderator
Moderator
Hello cdml,
Here at Solidigm we can assist you with technical and warranty support for current and former Intel NAND SSDs.
After checking your inquiry, it will be better if you post your question in the DELL community or if you open a support case with them. They should be able to guide you and share compatibility details of the products that you are using.
If you have any questions or concerns regarding the Intel NAND SSDs, do not hesitate to visit our support site at www.solidigm.com/support
Yordan
Solidigm Customer Support.
