What is the maximum power consumption of the SSD 7600p when operating at maximum write and read speed?
JBogg3
1 ACCEPTED SOLUTION
JosafathB_Intel
Valued Contributor
Hello JBogg3, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
7 REPLIES 7
JosafathB_Intel
Valued Contributor
Hello JBogg3, Thank you for your patience. The power consumption of this drive while active is 50mW, idle 25mW and Sleep is 3mW. We hope you find this information helpful. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Valued Contributor
Hello JBogg3, Thank you for contacting Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Valued Contributor
