Using NVMe-MI command for two P4510 SSDs
05-28-2018 12:16 AM
1.Reading SN/SMART for Multiple SSDs
Example for NVMe-MI appendix A for read VID and serial number.
Now, I have two P4510 SSD, and try to use SMBus to read some information by NVMe-MI 1.0a Appendix A specification.
Following table is data of VID and serial number by NVMe-MI 1.0a Appendix A example 2.
only plug SSD1only plug SSD2Plug SSD1&SSD2 on same motherboard80 86 42 54 4c 4a 37 33 37 32 30 41 50 45 31 50
30 46 47 4e 20 20
80 86 42 54 4c 4a 37 33 37 33 30 30 46 4c 31 50
30 46 47 4e 20 20
80 86 42 54 4c 4a 37 33 37 32 30 00 40 44 31 50
30 46 47 4e 20 20
By SMBus, SSD1 should win bus arbitration at value 0x32 of Byte 0x9.
But in "Plug SSD1+SSD2 on same motherboard" case, the value of Byte 0xb/0xc/0xd are logical and result of SSD1 and SSD2 TX data (that meaning both devices still driving data line).
How can I get correct serial number for two P4510 SSDs?
2. No reaction for NVMe-MI Reset Arbitration
As NVMe-MI 1.0a Appendix A example 3, host sending command to SSD device, SMBus Arbitration bit of Status Flags of Subsystem Management Data Structure should be clear to 0.
And then host send SMBus block read of device's status , but host receive SMBus Arbitration bit is 1 after sending this command.
My platform:
HP F5G73AV Z840
smbus driver:
I2C Tools
訊息由此人編輯:家豪 楊
05-31-2018 08:43 AM
As you seem to be using a dual Xeon® processor, one thing that you could try and test is to segment the PCIe lanes in order to connect one SSD on CPU 0 and the other one on CPU 1. Basically, you would be plugging one drive per CPU PCIe lane/slot.Additionally, could you please share the exact commands you are using to query the SMBus?Regards,Diego V.- Mark as New
05-31-2018 09:12 PM
Actually, my platform only using one Xeon® processor.
I want to know how can I get any information according to the documentation from the NVMe Technical Note: NVMe Basic Management Command: http://www.nvmexpress.org/wp-content/uploads/NVMe_Management_-_Technical_Note_on_Basic_Management_Co... http://www.nvmexpress.org/wp-content/uploads/NVMe_Management_-_Technical_Note_on_Basic_Management_Co....
The following commands I would use to query the SMBus.
SMBus block read of drive status:
Start D4 00 Start D5
SMBus block read of static data:
Start D4 08 Start D5
SMBus send byte to reset Arbitration bit:
Start D4 FF Stop
I2C read of status and vendor content, I2C allows reading across SMBus block boundaries:
Start D4 00 Start
My question is
1. When I use SMBus block read or I2C read command for pluging two P4510 SSD, I get the output is the result of an AND logical operator.
2. "SMBus send byte to reset Arbitration bit" has no reaction.
I expect that the SMBus Arbitration bit from "Figure 1: Subsystem Management Data Structure" of NVMe Technical Note: NVMe Basic Management Command would be cleared to "0", but in vain.
06-01-2018 07:17 AM
Thank you for the clarification.
Please let me investigate on your questions. I'll share here any information I'm able to find about it as soon as possible.
Have a nice day.
Regards,
06-05-2018 07:17 AM
After investigating about your questions and your platform, we realized that the system you are using (HP Z840 Workstation) doesn't seem to support the Intel® SSD DC P4510 Series. According to the following document, this workstation supports only the Intel® SSD 750 Series: http://www8.hp.com/h20195/v2/GetPDF.aspx/c04400043.pdfAs we don't see anything wrong with the commands you are using, we recommend you to try and test plugging the drives in different slots to confirm the issue is not because of where the drives are plugged in. However, considering the information from the HP Z840 documentation, we strongly recommend you to contact the OEM (HP in this case) to confirm if these drives are supported or if the only one supported is the Intel® SSD 750 Series: https://support.hp.com/us-en/contact-hpI hope you find this information useful.Have a nice day.Regards,Diego V.- Mark as New
06-05-2018 10:54 PM
I have used U.2 to PCIE adapter board, and this Workstation can recognize both P4510 SSDs.
I will find another Workstation to try NVMe MI Appendix A.
By the way, does P4510 SSD SMBus interface support device arbitration?
