SSD Toolbox crashes after system migration
12-04-2014 09:36 AM
I have an HP win 8.1 system running a stripe set of 530 240 Gig SSD. SSD Toolbox worked fine when there was only one drive but I added a second one and set it up in Raid 0. After migrating the OS to the new stripped volume on the Intel Rapid Storage RAID, SSD Toolbox crashes every time. I tried to reinstall it but it still crashes. I'd like to run this program to keep rack of the drives age.
12-05-2014 07:56 AM
I would like to get more information about the system you have.
Please provide the following:
- What is your computer model number?
- What SATA chipset are you using to connect the SSDs?
Kevin M
12-05-2014 08:10 AM
Your Second Drive might be defective, but need more information to come to a conclusion though
01-13-2015 02:09 PM
Hello GedLee,
Could please try this drive in a different computer to see if the same thing happens. Please make sure this drive is running the latest firmware version.
Use our Intel® SATA Solid-State Drive Firmware Update Tool and check if there is any update to its firmware. use this link to lead you to our Intel® SATA Solid-State Drive Firmware Update Tool found in our download center. https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363 Intel® Download Center
Let us know as soon as possible if this helped you.
