Should I expect problems with a DC S3500 SSD without AHCI/Trim?
MArit
we have some systems with Atom CPU (D525 CPU and Intel ICH8).
Bios does not offer AHCI, only IDE.
Harddrive is a intel SSD DCS3500 2,5" 80GB.
Windows 7 Prof. will be the OS.
The SSD in these systems are not used for better performace but for reliability issues.
The user will not have any admin rights.
I know that without AHCI, there will be no Trim Support.
How much will the missing of Trim Support impact the SSD in a performance and reliability view?
Will the internal Garbage Collection of this SSD help in anyway?
Are there any better SSDs for this situation?
Thank you!
1 ACCEPTED SOLUTION
ASouz7
Valued Contributor
Hello MartinArith,
Answering your questions:
There will be very little impact in terms of performance. These SSDs come with a number of features that enhance the reliability and performance all together. Please understand that without AHCI you will not be able to get any smart detail readings such as the ones found on the Intel® SSD Datacenter Tool.
As for the garbage collection, it will help but does not replace TRIM.
Garbage collection collects used pages into entire used blocks, thus making more space available for immediate writing and reducing writing amplification. When a file is deleted, the pages of the file are not touched. It is done with the directory entry in the filesystem.
All Intel® SSDs have TRIM and Garbage Collection as standard features. The Intel® SSD DC S3500 and other data center series have additional space so the data can be moved and the impact of not having TRIM is down to a minimum.
Let us know if this helped to answer your questions.
3 REPLIES 3
ASouz7
Valued Contributor
Hello MartinArith,
MArit
Hello Aleki,
thank you.
We will then give it a try.
Bye
ASouz7
Valued Contributor
MartinArith
We are glad we were of help. Please let us know if there is anything else you need.
Best regards.
