07-31-2018 02:56 AM
Is there any documentation regarding Intel SSD smart value recommended thresholds to monitor?
I'm am particularly interested in DC S4500's as support article mentions that for example "Pending Sector Count" will be much higher than on older gens
and will change often and can be ignored to some level.
Do I even need to have Nagios NRPE smart_check scripts poke these values on S4500's and if I need then what threshold should be set there?
support article ref:
* https://www.intel.com/content/www/us/en/support/articles/000027708/memory-and-storage/data-center-ss... https://www.intel.com/content/www/us/en/support/articles/000027708/memory-and-storage/data-center-ss...
Regards,
Rudais
07-31-2018 12:07 PM
Hello Rudais.
Thank you for contacting Intel Technical Support.As we understand, you are interested in learning more about SMART attributes related to your Intel® SSD Data Center Family DC S4500 Series. If we infer correctly, we recommend you to visit the following link:https://www.intel.com/content/www/us/en/support/articles/000023512/memory-and-storage/data-center-ss... https://www.intel.com/content/www/us/en/support/articles/000023512/memory-and-storage/data-center-ss...The https://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/Intel_SSD_Smart_Attrib_... Intel® Solid State Drive Data Center for SATA SMART Attributes (PDF) includes recommendations and a table listing the SMART attributes supported by the Intel Data Center SSDs for SATA.The Intel's Data Center Tool (DCT) can be used to read out the SMART attributes to download this tool please follow this link:https://downloadcenter.intel.com/download/27863/Intel-SSD-Data-Center-Tool https://downloadcenter.intel.com/download/27863/Intel-SSD-Data-Center-ToolWe hope you find this information useful. Best regards, Josh B.Intel Customer Support.- Mark as New
07-31-2018 12:07 PM
Hello Rudais.
08-01-2018 03:52 AM
Thanks for reply.
I hadn't yet looked into viewing smart via DCT linux version. It looks that this will be much better option to check drive health with than standard smartmontools - smartctl.
As I can just run periodical selftests via cron and check "DeviceStatus" value and maybe separate attribute "Action" values. That way I don't have to do any interpretation as I can just
check the statuses that DCT outputs.
Now just to create NRPE script for that.
