S25-M 160GB SSD Will format as FAT32 but not as NTFS. What's up with that?
08-18-2013 10:18 AM
Windows 8, Intel SSD 160GB. NOT the system drive.
When I installed the drive the system saw it. I then tried to format it as NTFS but Win 8 would not format the drive that way. After a few failed attempts at that I tried to format it as FAT32 and that worked.
I can probably use the drive fine in FAT32 mode, but I'd prefer to use NTFS.
Do any of you have any suggestions or ideas?
Thanks,
Rich
08-19-2013 09:27 AM
Hello Rich,
The issue seems odd; however, as I am not aware where is the drive connected to, I would like to suggest using an internal SATA connection or different SATA controller (SATA port 0). If the issue is present that way, you may try a secure erase using the Intel® SSD Toolbox and then try formatting it again. Otherwise, I hope you can also format it in a different system.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455
