Media_Wearout_Indicator going up?
AKvis
I have been monitoring Media Wearout Indicator for a while, but I saw something odd in our Munin graphs, so I dumped the output of smartctl every minute and here are the result:
233 Media_Wearout_Indicator 0x0032 091 091 000 Old_age Always - 0
233 Media_Wearout_Indicator 0x0032 092 092 000 Old_age Always - 0
[120 lines with value:092 removed]
I tought the Media_Wearout_Indicator were going down from 100 as the drive were wearing out and that I could expect failure when it hits 0 - how is it going up again?! The value have been on 091 all the time since I've started monitoring it, but like the above, the value is 092 for a couple of hours before going down to 091 again...
=== START OF INFORMATION SECTION ===
Device Model: INTEL SSDSA2M120G2GC
Serial Number: ******************
Firmware Version: 2CV102HD
User Capacity: 120,034,123,776 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 1
Local Time is: Tue Jul 2 14:39:14 2013 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
/Anders
5 REPLIES 5
Jose_H_Intel1
Valued Contributor II
I would recommend monitoring this value with the Intel® SSD Toolbox just to make sure the reading is correct. Additionally, you may run some diagnostic tests on the drive with the same software utility.
Intel® SSD Toolbox
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455
It looks like Intel SSD Toolbox is Windows only?
The disks are in a server running Linux, that's why I read the values with smartctl...
Reading in the Intel SSD Toolbox user guide it looks like it uses S.M.A.R.T. the same way as smartctl to read the attributes, so the tool shouldn't give any other values. I'm using it for some Samsung SSDs as well that increases quite fast compared to Intel SSDs...
E9
Reports the number of cycles the NAND media has undergone. The normalized value declines linearly from 100 to 1 as the average erase cycle count increases from 0 to the maximum rated cycles. Once the
normalized value reaches 1, the number will not decrease, although it is likely that significant additional wear can be put on the device.
/Anders
Jose_H_Intel1
Yes, the Intel® SSD Toolbox is for Windows* only.
I did not fully understand your statement regarding the Samsung* SSDs. Is the same happening with those?
We may assume that we will get the same readings from both software utilities; however, it is better to know for sure and discard the possibility of a software issue.
No, we just see the Samsung disks wearing very fast compared to our Intel disks - values only going down...
Unfortunately, it's not an option to boot Windows - it's a Linux server with quite high load and everything depends on it
I know this isn't a disk made for server use, but now that Intel also makes SSDs for serveruse (S3700 and S3500), are there any plans to make own utilities that can run on Linux?
The above mentioned server is scheduled for retirement within a half year and will be replaced with a equal server with S3500 disks, so I will be able to test the disks, but it's going to take a while...
