Issues running "check for update" on Intel solid state toolbox
02-13-2014 08:26 PM
l ssdI am getting an error running an update through the Intel Solid State Toolbox. It is something to do with microsoft .net framework. However, I can not do a reinstall of .net framework on Windows 8.1. The dialog error box is listed below.
My computer specs
Windows 8.1
ASROCK Extreme3 motherboard
AMD FX-6100 processor
8 GB
Geforce EVGA 760 GTX 4 GB Graphics card.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): Class not registered at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo) at System.Diagnostics.Process.Start() at System.Diagnostics.Process.Start(ProcessStartInfo startInfo) at gui.FirmwarePanel.button_link_Clicked(ImageButton button) at controls.ImageButton.raise_Clicked(ImageButton value0) at controls.ImageButton.ImageButton_MouseClick(Object sender, MouseEventArgs e) at System.Windows.Forms.Control.OnMouseClick(MouseEventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll----------------------------------------Intel SSD Toolbox Assembly Version: 3.2.1.400 Win32 Version: 3.2.1.400 CodeBase: file:///C:/Program%20Files%20(x86)/Intel/Intel(R)%20SSD%20Toolbox/Intel%20SSD%20Toolbox.exe----------------------------------------msvcm90 Assembly Version: 9.0.30729.8387 Win32 Version: 9.00.30729.8387 CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_5094ca96bcb6b2bb/msvcm90.dll----------------------------------------System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.F...----------------------------------------System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------controls Assembly Version: 1.0.0.0 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/Intel/Intel(R)%20SSD%20Toolbox/controls.DLL----------------------------------------msvcm90 Assembly Version: 9.0.21022.8 Win32 Version: 9.00.21022.8 CodeBase: file:///C:/Program%20Files%20(x86)/Intel/Intel(R)%20SSD%20Toolbox/msvcm90.DLL----------------------------------------Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Microsoft.Win32.TaskScheduler Assembly Version: 1.9.4.17032 Win32 Version: 1.9.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Intel/Intel(R)%20SSD%20Toolbox/Microsoft.Win32.TaskScheduler.DLL----------------------------------------System.Management Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.d...----------------------------------------CustomMarshalers Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll----------------------------------------************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.X...
02-14-2014 08:31 AM
I am sorry the issue.
There is the option to repair Microsoft*'s .NET framework from Programs and Features. You just need to highlight this software component and click "Uninstall/Change", then continue with the wizard using "Repair…" until it completes.
