intel toolbox won't start in xp
08-16-2013 02:27 PM
toolbox use to function but now it wont start. i install reinstall numerous time but wont start... when i click on the toolbox icon i see the hourglass for a fraction of second but wont start... i am using xp everything is update anyone can help me thanks
08-19-2013 09:39 AM
Hello Korsaire,
Since you already reinstalled Intel® SSD Toolbox the cause of the issue should be something else.
Please try repairing your installation of Microsoft*'s .NET Framework. Usually such option is available in newer versions of Windows*; however, you may search for it in Add/Remove Programs in Control Panel. Otherwise, you may need to uninstall and reinstall .NET Framework.
08-23-2013 06:00 PM
that have not work too. thanks for the help
08-26-2013 10:48 AM
Perhaps rolling back with Windows* System Restore may help. Otherwise, it might be related to the operating system itself.
