10-27-2017 04:51 AM
On tests the read speed of dc p4500 never gets higher than 1500MB/s. Same results on different systems and motherboards(pci 3.0).
There is some way to circumvent that?
10-27-2017 02:07 PM
Hi victer,
We understand your concern regarding the performance of the Intel® SSD DC P4500 Series. In order to better address your situation, could you please provide the following information: -What is the operating system you are using? -Are you using the SSD as a storage device or are you using it as a boot drive? -What is the tool you are using in order to perform the benchmark? -Please download and install the https://downloadcenter.intel.com/download/27130/Intel-Solid-State-Drive-Toolbox Intel® Solid State Drive Toolbox. Once is installed, hit the "Export" option and attach the file. We look forward to hearing back from you.Regards,Junior M.10-30-2017 03:27 AM
10-30-2017 01:37 PM
Hi victer,
Thanks for the information provided. Based on the logs, it seems that the SSD is connected to a PCIe port 3.0 by 2 lanes. We suggest you to install the SSD in a PCIe port 3.0 by 4 lanes. Please let us know if that works. Regards, Junior M.10-31-2017 08:42 AM
Hello, i did try your suggestion, but no good, same speeds.
Even when i try on a 16x gen 3 slot, the speed stays the same.
