Intel 660p 2TB SSDPEKNW010T8 Reflash Firmware
12-01-2022 02:36 AM
Model: INTEL SSDPEKNW010T8
SN: BTNH01740L6L1P0B
my Intel 660p 2 TB is failing on me. It goes offline every 5-6 hours stating fatal error when I try to open it after it has crashed.
A reboot makes it active again. I tested different storage control drivers, tried to flash the firmware with intel and solidigm tools but they can only perform an update. Since I am on the latest firmware 005C already I can't update. I need to reflash 0005C or downgrade to 004C. Please advise?
12-07-2022 08:21 PM
Hi pitha76,
I would suggest to use the Solidigm Storage Tool and run Full Diagnostic scan to check the health of your SSD. After the scan, you can export the SMART logs and share it with Solidigm customer support for them to check if there is other issue that may be contributing to the fatal error.
No need to reflash the firmware since it is already the latest version.
Hope this helps.
