06-01-2017 09:22 PM
After updating to the latest firmware my write speeds are that of a normal HD.
06-26-2017 12:56 PM
Hello Exposed,
Thanks for the reply. You can basically just go and do the writes test, at the end it seems that is the test you really need to measure.Please let us know if you need assistance and making sure to follow the instructions to properly set up the test.Regards,Nestor C06-26-2017 04:29 PM
06-27-2017 01:24 PM
Hi Exposed,
Thanks for the files.We'll be looking into the logs and we'll get back to you. Please stand by for our update.Regards,Nestor C06-29-2017 01:40 PM
Hello Exposed,
We have been trying to reproduce the situation with no luck, in our disk, it runs fine and even better after the firmware update.Since we have not been to reproduce this, is there any way for you to reload the operating system? We believe there is an issue with the native NVMe* driver from Microsoft*, so, if you can try this, we can discard the operating system as the culprit.Regards,Nestor C06-29-2017 02:16 PM
Hey, could you please post your results and your system specs? It would be interesting to see how yours runs better.
