i have an ssd of 80 gb capacity intel ssd x25-m current firmware is bt16b030. i have tried updating the firmware using the intel ssd firmware update tool version 3.0.7 . its not updating at all.
Tried in pc and in laptop using the pendrive.
11-18-2019 08:08 PM
I need to 4pc10362 firmware file in binary format to update the firmware.
hope you guys will come with a solution for me.
Thank you
11-18-2019 08:28 PM
Download and install the latest version of Intel SSD Toolbox: https://downloadcenter.intel.com/download/28808/Intel-Solid-State-Drive-Toolbox?product=80096. Using this tool, you should be able to update your SSD firmware.
Leon
11-19-2019 03:00 PM
tool is not getting installed showing error, operting system is not supported
11-19-2019 05:26 PM
Hi @mak
- The Intel SSD Toolbox, is supported in Windows only. For Linux O.S. you may use Intel® SSD Firmware Update Tool: https://downloadcenter.intel.com/download/28749?v=t .
- Before using the Intel® SSD Firmware Update Tool, please read the User Guide:
https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/Intel_SSD_FUT_User_Guid...
3. The Legacy Boot should be enabled and Secure Boot should be disabled.
Leon
